It is currently Mon Aug 18, 2025 8:25 am
PostPosted: Sat Apr 17, 2010 10:07 am
First name: Dan
Last Name: Pennington
City: Brooklyn Park
State: MN
Zip/Postal Code: 55428
Just bought a used drum sander. What grit belt is best?
PostPosted: Sat Apr 17, 2010 10:09 am
First name: Glenn
Last Name: LaSalle
City: Saint Petersburg
I use 80 on my Performax 10-20
Glenn
PostPosted: Sat Apr 17, 2010 10:15 am
I use 80 grit for hardwoods, 100 grit for spruce tops. Then I use a scraper, then finally sand.
PostPosted: Sat Apr 17, 2010 10:42 am
First name: Dan
City: Brooklyn Park
State: MN
Colin & Glenn, thanks for the info.
I bought a Delta 13-250 drum sander (18 inch capacity) from a door and window wood worker who needed a bigger machine. For less than I was about to pay for a new Jet 10-20. Amazon sells 100 grit belts for a good price. They don't stock 80 grit, so I think I'll go with the 100 grit to see how it goes.
PostPosted: Sat Apr 17, 2010 11:23 am
I had been using 120, but it loads up pretty qucikly on me when sanding a lot of rosewood. I've gone to 80 and that has worked better.
PostPosted: Sat Apr 17, 2010 11:34 am
First name: jeff
Last Name: parker
City: anchorage
State: ak
Zip/Postal Code: 99516
I think you will find that 100 is too fine to use other than as a finish grit or a very low oil or low density type wood. On a hardwood the grit will load up and leave burn marks. You can use grits as coarse as 36 if you need to remove a lot of stock otherwise 60 is a good choice to get you near the final thickness then smooth the surface with your 100 grit. You can salvage your burned belts with oven cleaner. I hope you have a good dust collector or else you will be coughing up dust balls for a while. Have fun!
PostPosted: Sat Apr 17, 2010 11:44 am
I bought several grits when I got my Jet 10-20 but have ended up using 80 grit. As others have said, the finer grits load up too easy.
PostPosted: Sat Apr 17, 2010 11:52 am
You need different grits.
120 is OK for the few last passes, but an orbital sander can do the same job quickly.
I use 36 for quick thicknessing. For instance I received African blackwood sides that were .200" thick, I can't imagine how much time and belts it would have taken to bring them to .075" with 100 grit.
80 grit is the most used, I also use 60 grit blue zirconia to remove stock relatively quickly, it lasts forever and runs a bit cooler, but tends to leave deeper scratches. I rarely use 120, only to thickness veneer to .010" when I need more accuracy.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Sat Apr 17, 2010 1:47 pm
What Laurent said. 100 on its own is too fine in my experience.
Chuck
PostPosted: Sat Apr 17, 2010 4:33 pm
I use 60, 80, and 120 (tops).
PostPosted: Sun Apr 18, 2010 7:58 am
I use 80 for hardwood sides& backs and 120 for the softer spruce tops. I found 36 to be too harsh, leaveing deep scratches that were hard to get out without alot of work on the back& sides.
PostPosted: Sun Apr 18, 2010 8:51 am
First name: Dan
City: Brooklyn Park
State: MN
After reading more opinions on grit size. I've changed my mind. I just ordered some rolls of 60 and 80 grit. That should get me into the ball park.
Thanks for responding!
PostPosted: Sun Apr 18, 2010 9:05 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
If the wood is quite thick like over 1/8th I start with 60 then switch to 80 when I get closer, the 80 loads up if you are doing a lot of stock removal. I then smooth out a bit with my RO sander.
Fred
Fred Tellier
PostPosted: Sun Apr 18, 2010 9:06 am
First name: george
Last Name: wilson
City: barhamsville
State: virginia
Zip/Postal Code: 23011
Country: united states of america
The coarse grits like 36 are best for general sanding. You can cautiously follow up with 120,but anything finer is going to pack up the belt right away.
On my Delta,I use about 1/8 turn for each new cut. And, often,the board can be run 2 or 3 times at the same setting and still cut. I like the Delta better than the moving head types,such as Performax. I can always put my finger against their heads,and my thumb on the conveyor belt,and flex the head. On the Delta, the head is securely welded,and it cannot flex. The table is rigid,too. There has been trouble with the belt that turns the elevating screws getting out of sync. I urge you to not crank the table up and down rapidly,or excessively. So far I've had no trouble with mine,but others have had trouble.
PostPosted: Fri Apr 30, 2010 5:18 pm
First name: Jay
Last Name: Gordon
City: Port Townsend
State: Washington
Zip/Postal Code: 98368
Ahhhh...dual drum sander...disadvantage: aligning the drums...advantage: two grits in one pass.. 80,, then 100. Thickness and then reasonably smooth to continue assembly. My Grizzly is crude but effective!
PostPosted: Fri Apr 30, 2010 6:26 pm
Do you take the sandpaper roll of the drum sander to use the oven cleaner or can I just spray it on the drum and then brush it off? I assume I brush it off maybe I need to do something else.
I think I use 80 grit to get the sides, backs and tops down close to what I want as anything beyond that seems to clog up more on my 16 x32.
Chuck
PostPosted: Fri Apr 30, 2010 7:10 pm
First name: jeff
Last Name: parker
City: anchorage
State: ak
I have always used the oven cleaner off the machine. I usually wait till I have 5 or 6 belts to clean then soak them in a five gallon bucket then rinse them off and let dry. Helps to have a pressure washer to get all the burned material off. Jeff
PostPosted: Fri Apr 30, 2010 9:22 pm
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
60 or 80 depend wood to get it down and close. 120 to get it within a few thoug and finish 150 or 180 depend what I grab.
PostPosted: Sat May 01, 2010 6:49 am
With all of the grit changing recommended, do you 10-20 folks have secret easy ways to change belts?
PostPosted: Sat May 01, 2010 6:59 am
I leave 80 grit on my 10-20 and sand to 220 with my ROS. I got in the habit of using the ROS or jitterbug sander to sand all my parts to 220 when I built furniture and, anyway, I'm too lazy to bother changing belts all the time.
PostPosted: Sat May 01, 2010 8:44 am
Nope. I found it quite easy after about 6/8 changes. I don't use the tool supplied, only my fingers. Just open clip, one end in on the left lined up to the edge (end abrasive bent to 90 degrees), wind with small space between wraps, bend abrasive at 90 degrees where it meets the right hand slot edge, insert to clip, release clip.
Run briefly then check all OK (evenish gap all the way, no overlaps and fairly taut).
I'm just lucky my fingers fit reasonably.
Users browsing this forum: Ken Lewis and 14 guests
